Fan Rattle
Whitefish
Lamoine, Maine
I have aquired a very annoying rattle which appears to be blower fan related. Turning the fan off kills the rattle. I do not believe anything fell down the defrost outlet. In any event, how does one get to the blower assembly? Thanks for your response.
Rattled in Maine.
snowwind1990
springtown, tx
Check out the blades real close. You may have chipped one....well YOU may not have, but the Crow that flew up there could have...Know what I mean? eek!
You can access the plastic blower fan wheel from under the dash and through the dropped glove box. Remove the metal clips that hold the plastic tray under the blower ducting. You will see the hex head screws that hold the panel onto the blower box. You must remove or move a few air duct hoses and the blower control module to access all the screws. Once they are out, the panel can be pulled to provide a direct view to the blower wheel and the source of you fan rattle. Probably paper that was drawn into the recirc opening from the glove box.
While you are in there, you should also pull the blower wheel and clean it. You should also clean the evaporator fins of the accumulated dust that is undoubtedly clogging the flow of air through it. I used damp towels and a vacuum cleaner to clean mine just a few months ago. I found a great deal more air flow after the cleaning that was obviously being blocked by the buildup of dust and dirt.
