exhaust, radiator, fog lights
HoustinoJillian
name's JUSTIN
usa
need to replace both mufflers- whre can i get parts and how much (stock)
heed to replace reservoir on radiator (my radiator's fine, but hte reservoir is crap and thats where the sensor is so i cave low coolant dummy light on... and finally,
my car has fog lamps, and a fog lamp switch, but no matter which way the switch is pushed, they dont turn on ?and ideas? settings that should be changed? thanks
93nighthawk
Mitchell, SD
1. You can get cat back exhaust for about $450 at summit racing or jegs online if you want the stock sound. You can also check out the www.shoshop.com they sell custom exhaust and I think someone around here also does.
2.Does the resivour leak? if not take it off the car and clean it. That should correct the sensor problem. Otherwise check the local junkyards.
3. There is a fog light fuse seperate from the fuse panel by the fuse panel. Check to see if that is blown. If it is good, Turn on the fog lights and take a omh meter or something similar to check to see if it is getting power.
Hope this helps,
Eric
HoustinoJillian
name's JUSTIN
usa
thanks a bunch- is that the least expensive exhause around, i don't want performance, just something to get through inspection next year, also, i believe the reservoir is cracked, will one from a normal (non SHO) taurus or even a sable fit? i still need to check that fuse- i'll do it tomorow probably
Mick
Missouri
I paid about $250 for the exhaust for my 92 mtx from Summit racing. Included everything: tubing,clamps and mufflers.
Not too loud, sounds really good at idle!
The LOW COOLANT light is sourced from the sensor in the coolant expansion bottle. The sensor can be removed for cleaning or replacement by just rotating and unsnapping the cap. Check the two metal tabs at the lower tip of the sensor. Clean them if they are coated with crud or replace the sensor if the tabs are corroded severly.
