excieter ring front 60K
big b
barrington Il.
Well the front 60K has a slight setback, I was checking clearance on the Crank sensor so I did not have the sensor tightened down when I rotated the crank bolt.
So I bent the excieter ring behind the lower crank pulley.
Just curious if this is a part readily available to order? or I'm going to have trouble finding one.
crystizel
