stephen newberg
Well, my list had gotten toward 10 items, so I figured it was time to give this ESP thing a try. Took her in yesterday and they had her for the morning. Results:
Adjusted trunk lid spring tension.
Cleaned and lubricated telescoping antenna.
New alternator, installed.
New front wheel bearings, both sides, installed.
New front stabilizer end links and bushings, both sides, installed.
New transmission shaft seal, one side, installed.
Cost, $100 Canadian.
Items not addressed:
Mosture getting in front turn signal lenses. Apparently a normal Taurus thing which will happen even if replaced, and not covered, so not done until they stop working.
Paint bubbling on inner lip of trunk lid. They are checking to see if there is some way to cover it.
Metal rubbing at rear when with 4 passengers on bad bumps. Another Taurus thing, hitting exhaust, and worse on SHOs, they claim.
Well, I guess there is still no fix for the 115 mph speedo problem.
And they washed it, so for the next half day until it rains, the car is clean.
I suspect the ESP plan just paid for itself, and it still has a couple of years to run.
pax, smn
pax, smn
