Error codes what do they mean
gill2001
Bronx, NY
I was driving my car and the ce light turn on and stayed on. I got the codes from the computer but what do they mean.
235
335
122
157
648
please help. My cars idle is too high when parked and when I rev it in park it soars and stays where I took off my foot off the gas. I just changed the MAF. I fixed a broken vacuum hose on the egr. I thinks it a green hose. I also bought a TPS and I put it on and it gave me the same results. I took off the new TPS and put the old one and it seem to do better. Sorry for the essay but i need to knwo what is happening. Please help the SHO FOOL shoot
naval-avi8or
Chesapeake, VA
gill2001:
235
335
122
157
648
235 seems to be an invalid code.
DTC 335
Exhaust gas recirculation valve pressure sensor voltage higher or lower than expected during KOEO self-test.
DTC 122
Throttle position sensor circuit below minimum voltage.
DTC 157
Mass air flow sensor circuit below minimum voltage.
DTC 648
Incorrect gear ratio obtained for fourth gear.
I would rerun the test to double check all the codes, write them all down and then reset the computer. If the codes come back than there will be a need to troubleshoot each sensor for the proper parameters.
