Engine surging at 50 - 55?
rickshaw
Jacksonville, FL
I've resolved a number of issues thanks to all of you on the boards:hail:
But there still is a "surging" between 50 - 55mph. The car hammers out of the hole without hesitation ( except for the occasional TC squeal ) and runs fine at other speeds.
Any ideas? Time to change the fuel filter or could this be a trans issue? If it's the trans, I have a great parts car available!
thanks!
NebraskaSHO
Harumph!
Omaha
Push the vent button in the EATC and see if that helps. Or else just hit off too...
NebraskaSHO
Harumph!
Omaha
Yea. Either way will shut off the AC compressor I believe. At highway speeds with the AC on this is why the RPM's go up and down.
by the way, EATC = electronic automatic temperature control
macaddict
osage
I get this same similar surge but only in drive at speeds closer to 30-40 mph.
Any advise on this would be greatly appreciated.
wuzzzer
MN Moderator
St Cloud, Minnesota
Could very well be the sign of the torque convertor going bad. If you manually shift into 2 does the surging still happen?
rickshaw
Jacksonville, FL
I tried driving in 2nd and didn't notice the surging, but what does that mean? At 149K the TC is suspect, but why would the car launch hard from a dig?
HoustinoJillian
name's JUSTIN
usa
i dunno if its anything similar, but i had a surge at coasting speeds in my old 95 (i realise you're asking about a g3 not a g2).. turned out the sparkplug wires were getting old/worn out. replaced them and the plugs and it went away...
rickshaw
Jacksonville, FL
sorry to dredge this one up again, but I'm still living with this issue.
The cars starts fine, idles down nice and smooth.
I'd like to rule out coil packs and plugs.
Any ideas?
SHO SPD
SHO member #480
Naples, Florida
if it were plugs and coils you would notice a misfire. not really any surging. Have you tried to reset the computer? If not try that for starters. unhook the battery for a little while, or overnight and when you go to work in the morning see what happens.
JSIL1
Mainlining
Mile High and Gaspin
No hijacking intended, but i have a quick question. my 1-2 shift is ridiculously hard, the only way to prevent it is the start in second, or floor it from a stop.
My concern is, instead of a lone hard **** forward, it feels like the engine rocks, i.e., I feel the thud forward and then I feel a thud backwards. Both of these are easily heard
Could this be attributed to other things?
SHO SPD
SHO member #480
Naples, Florida
I would say its shifting so hard its rocking the drivetrain. Possibly broken motor mount or something may be causing it to be very defined. I also have the really hard 1-2 shift in my 93, but its been there for like 60k miles. The only way I avoid it is, well I dont, just shift to second first lol.
rickshaw
Jacksonville, FL
Yep, just tried it on a run to the store. Still is there.
I also smoked a kid in his A4!
rickshaw
bmytych
