Engine Spitting And Sputtering (Video Attached)
sabremike21
Midvale, Utah
Unless you fried something electronic, the problem would seem to be related to the work you just did. I would look again at the coil pack to spark plug wire routing again (happens more than you think where you're sure it's correct but it's not), fuel filter orientation, and maybe the exhaust has something plugging it up and choking it out.
Trust me plug wires are correct, I've triple checked just to make sure and that would not explain the symptoms anyway. I'm not a noob with working on cars and I know even the best have been known to mess up a time or two, but I know for fact the work I did has been done correct.
I am leaning towards the possibility the fuel pump, but have yet the chance to test the pressure. I am also going to go ahead and replace the cps and the maf for the **** of it as who knows if they have ever been changed out before and I get a good discount on parts through my work. As far as the exhaust, it's getting good flow out the tail so I doubt that to be the issue either.
sabremike21
Midvale, Utah
Ok so I finally got the car to run decent enough to pull codes and the first time I didn't goose it properly as it gave me a 111 and a 538. The second time it only gave me code 111 system checks ok, but it most obviously is not ok.
On a second note, would the cam position sensor or the crank position sensor cause the tach and lights to act weird?
sabremike21
Midvale, Utah
Ha ha, ok so even though the cam position sensor looked ok I changed it anyway and after an hour of trying to figure out the best way to get my hands into such a small place I got it changed and it runs absolutely amazing now.
I don't want the koer codes, I want the koeo codes. Just put on the jumper, turn the key to on, and read the codes for us.
