What kind of welder did you use to weld on the muffler? Did you disconnect battery and pcm connector before you welded? Because if you used any type of arc welder without disconnecting the pcm, you most likely killed the pcm.
I don't think those are the right codes. When you pull codes, it will flash the current codes, repeat them, then flash a single separator flash, then the stored codes and repeat them. Each section is reported from lowest number to highest number. Since the numbers you typed in do not follow that format, they are suspect. Please pull them again or make a video and post it so we can read them.
