engine running hot!!!
89SHOduff
Attleboro, Ma.
when I'm at a stoplight or just at a stop period, my thermostat pin goes passed the normal mark and goes way up towards the red of the hot engine mark. then my fan will come on, but it seems like the fan should come on earlier. Am I right or is this normal? My car never used to do this. Any info will be great.
shojuan
sunny San Juan Bautista,
The fan and the gauge each ahve their own temperature sender. The fact that your fan isn't coming on sooner suggests that there could be a problem with the gauge circuit. The small single wire one near the thermostat housing is the gauge sender. Pull the wire off, look for corrosion, and push it back on to make a good connection. See if that changes your gauge readings.
Rick
BeatDaSHO
Hatboro, Pennsylvania
your thermostat might be stuck also. i just went through 4 weeks of bull $hit with my car because it was getting wayyy too hot. I replaced EVERYTHING from the cooling system and it still is the same. I got this fan relay from pep boys that you can kick the fan on at any temperature and now i have it 27 degrees colder than what it was running at. It's not like it used to be but it sure is close enough now. But try the sending unit for the gauge and then the thermostat.
Greg
Huntervf
Bored now
Back in Michigan ... again.
You may also have a bad ECT sensor (engine coolant temp). This sensor directly controls the elect. fan operation. I just had a prob with my 89 running hot in stop/go traffic, intersections etc. My elect. fan was only working sporadically, then finally not at all.
The sensor is cheap and takes about 5 minutes to replace. You'll find the sensor near the thermostat, just a short ways past it, closer to the back of the engine. You'll see a two wire plug coming out of it, and the sensor itself screws right into the engine similar to the way the temp sender does. I used a 1 inch deep well socket to remove it, though I suppose the correct size is the metric equivalent (didn't have a big, deep metric socket.) Be sure to use teflon tape on the threads of the sensor when you replace it to help prevent leaks.
Also, I found out that most parts stores have this sensor in stock, price is anywhere from $20-$30. I won't guarantee this is your problem, but it's a good start.
slickn56
North Attleboro, MA
BeatdaSHO, what is that relay that controls the fan called? my fan is hardwired right now and ive been looking for a way to control it.
Thanks,
Nick
89 SHO
BeatDaSHO
well there are a couple different fan relays that you can get. The one I have it made by Hayden and can be found at Pep Boys. You can change when the fan comes on at by turning a screw. It costs 40 bucks at Pep Boys. I think the part number for it is 3647 but i'm not too sure on that. You can turn the fan on at temperatures between 90 defrees and 210 degrees. It's nice.
Greg
