I don't see my last post so I'll put it up again...
skipper said:
Any chance it could be the Distributorless Ignition System Module (DIS)?
Yes there is a chance that it could be a problem.
skipper said:
Will the CKP (CPS) cause there to not be a spark?
Yes.
But you still can't run codes which is really pointing to a computer problem. Check into finding out why you can't get codes before you try to diagnose anything else.
If you want to check your CKP sensor here are some directions for doing so posted by rangerj in the past:
All that having been said, here is how to test your CPS, (aka PIP or CKP) to control unit.
Connect a DMM or LED test light between the PIP wire (DB Dark Blue) and the negative battery terminal. Then crank the engine. The test light should blink, or the DMM should read betweem 3 to 7 volts.
If NOT, the crank sensor, crank sensor POWER or GROUND, or wiring is faulty.
PIP signal is OK, then next test, SPOUT to DIS module.
Connect DMM or LED to SPOUT wire( Y/LG Yellow Light Green stripe) and negative battery terminal, then crank engine. You should get 3 to 7 volts or the test light blinks. If NOT, the control unit or wiring( including connection) is faulty. If OK, next test.
Connect DMM or LED test light between the IDM wire(GY/O Grey/Orange stripe) and negative battery terminal and crank the engine. Again 3 to 7 volts or the LED light blinks. If NOT DIS wiring or module faulty. If OK, next test.
CID to Sensor. Connect LEDtest light between CID CS wire (DG Dark Green) and negative battery terminal and crank engine. The test light should blink. If not, CID sensor or wiring is faulty. If OK, next test.
COIL PWR. Connect LED test light between COIL PWR (VBAT) wire and negative battery terminal and put the key on. The light should be ON (LIGHT UP). If not COIL PWR wiring faulty.
DIS electrical tests concluded. Hope this helps, rangerj
