Engine problem...blown head gasket?
94shoguy
ny
So here's the deal, this is my first sho. When i run it i get white smoke from it burning oil, i pulled the plugs and the plugs are soaked in oil on both sides of the engine. Lend me you sho epertise and help me! Is that a head gasket? Or do sho's do this from sitting for a couple of months?
revhardSHO
Seattle, WA
typical problem on SHOs. Its the valve cover gasket(s), easy fix. Do a search, youll find all the information you need to know.
ghostrider
Mt Juliet, TN
Oil in the plug well seals would definitely point to plug well seals being bad. You can get those plug well seals with the valve cover gasket set. Roughly $70 from autozone. Fel-Pro VS50378R. Very easy to fix, and while you're doing it. You should also think about getting new plug wires and plugs. Unless they are very new.
