Engine oil
ReGet
Russia
Hi
What oil i should use while running in 3.2 SHO engine? And what oil use after this?
SHO#7
Cincinnati
Your brands may be different over there. But I highly recommend that you search this subject. There are countless threads on it. Everyone has an opinion.
Mike
ReGet
Russia
Maybe I too stupid or dont know english language enough to find threads about oil.
I will be lucky if you give me link
Mr Anonymous
Tire Wall
You'll need 5 quarts of 5W-30 oil, changed every 3000-5000 miles depending on your driving habits and environment. Fresh oil, any brand, any forumulation (conventional or synthetic), frequently is all that really matters.
AREA 91
PA SHO SHOP
Area 91
Good luck with the SHO! I think you should get a personalized license plate!
MIG SHO
ReGet
Russia
ManySHOs said:
Wow, you are in Russia? I would imagine that SHO's are not common there? :salute:
In our capital there is only 10-20 SHO's, parts for them are too hard to find :eek:
Y
yamapowered
Guest
its cold in russia isnt it? if so stick with light viscosity.
try to find a oil that has the lowest pour point -50/-60
the lower the pour point the easier it is for the oil to lubricate
during start up when wear is most present.
Javier
ReGet
Russia
by the way, who can ship some sho parts to Russia? I can pay by PayPal
ReGet
Russia
USPS ships to Russia. Is there any sho shop, that can ship parts to Russia by USPS?
TankII
Bolton, CT
FPS probably would.
http://www.fordspecialists.com/
A few cold weather items:
Grease all cables (E-brake, clutch) every year so that any water caught in the cables is removed. Same with your tie-rod ends and stuff.
Make sure that your T-Stat is working properly at 192 deg f.
Use 5w30 Synthetic (I use 10w30 in the NorthEast were it gets as low as -7C) only because you do get consistantly colder weather there than here.
TankII
SHOtimer
#2910
Santa Clarita, Ca
I'm sure that most shops would, you just have to let them know that you are in Russia and you will incure more shipping charges.
Doug
