Corey
Ok, I took off the MAF today, and cleaned the filaments, although they did not look dirty at all. The car still runs like crap. I am going to change the wires tomarrow to see if that helps, but I have a question. Does anybody know how to test the MAF to see if it is good or not. I ran a test, but I dont know if it was the right way to do it. The chiltons manuel says that you must use some sort of connector to be able to check the voltage. Well I disconnected the plug, ran a jumper wire from the power connector of the plug to the connector on the MAF. I had the car running, and I tested the other three connector pins on the MAF. The two middle pins gave me a .8 volts, and the last pin gave me a zero reading. Has anybody tried this, and if not, will somebody please try it to see if they get the same thing. The chiltons manuel says the voltage when tested with that connector thingy must be between .38 and 1.5 or something like that. I am just trying to eliminate different problem areas. I will let you guys know what happens with the changing of the wires, and if anybody can answere my question about the test it would be appreciated.
Thanks
Corey
Thanks
Corey
