lndshark
Jolly Mon
OK. Dont know why I try to work on my car, seems like something like this always happens. about a week and a half ago my "new" 93 MTX starting surging when i was driving it. very intermitentaly, every other minute or so. So i think to myself, ah ha, must be the IAB. So i was planing on taking the manifold off anyway, might as well clean it out along with the IAB. I also figured that i would change plugs and wires as long as i had easy access to them. So i bought new plugs autolite ap3924, i know some of you will crucify me over this, but i found several people that say they work great for them. New wires, some premium brand, 100 bucks with a mechanics discount, my friends. I also plut in new intake manifold gaskets, and a new throttle body gasket. when i put the manifold back on i wasnt sure if it was seated right. i could push on one corner and it would move a little bit. on the oposite corners though, it wouldnt move at all. I went ahead and bolted it down, everything lined up and went back together. My battery was drained so i jumped it this morning. right away it started running like crap. sputtering, it would idle up to like 1200 then drop to 200. it would continue this for a minute or so, and then it would die. I checked everything over again and found the little black canister that is on the back of the manifold had a vac line that was coming out that wasnt connected. reconnected this but nothing changed. it will start up idle roughtly and jump all over the place. when i give it gas it will shake and sputter. what can this be. Anybody have any ideas. I could sure use some ideas.
thanks
brian
thanks
brian
