SHO Gods
Car: 1994 Taurus SHO, Auto, 120K
Just got done doing the 60K- gaskets, plugs, wires, etc, thought the maintenance would fix it...
btw, this problem existed before the maintenance.
Car starts right up no problems, the problem can occur in park or in drive, give it gas or "stomp on it" and you can hear an breath of air from the front of the engine then it dumps like it's going to die, then it will slowly rev up to whatever rpm you are gassing it to. If you slowly ease into the throttle it will rev up fine, but if you give it gas quick, it dumps again.
I tried, all gears, forward and reverse- does the same thing.
Any ideas?
TIA!
!!!Car: 1994 Taurus SHO, Auto, 120K
Any ideas?
TIA!
