Engine Cover Spitballing
How does the engine cover look?
  • Looks great
    Votes: 2 25.0%
  • terrible, **** it with fire
    Votes: 4 50.0%
  • With some revision (Which I included) could be great
    Votes: 2 25.0%
  • Total voters
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
looking good! is the SHO cut out and it's just a square lexan on the backing or what?
Wsho
Sacramento California
I applied epoxy resin on the back to fill in the letters that are pressed into the plastic that forum the letters SHO. Then sand down the front until you get to the epoxy resin. Then Put a light behind it and Wallah light up SHO badge.. it's the same concept that i used when I did my Fender badges ..
60581141411  C0152D95 FD31 4740 9BA8 432018C1A2AB 1
jman1200
Ontario
What epoxy resin are you using?
I like the concept but since you cut it, want to see how that looks.
Wsho
Now I'm putting the Ends on so it doesn't have that plain cut look. Right side almost done. Used no glue putting these piece together, left side just finished melting still need sanding. Melted the plastic together has more of a natural look and pretty strong still a ways to go.
IMG 0228 IMG 0229
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Coming along nicely. Will be cool to see it light up as well as show off your painted upgraded throttle body and color matched to platinum white hotpipes
Wsho
Yeah slowly but surely hopefully have everything on in about 2 to 3 months.
