Yamaha V6
SHO Enthusiast
Well, I was hoping it was a slack cam chain / tensioner, but it ended up being something a TAD bit worse...
After pulling the intake & covers, and seeing that everything looked totally MARVELOUS (Castrol GTX, baby), I decided to address a whining / bad bearing pulley on the accessories & timing belt. I wasn't totally convinced that the marginal Alt idler pulley & marginal PS idler pulley were the cause, so I started pulling the timing covers off...
Got the top one off, and saw a TON of red / iron dust over everything. Of course, I was like, "Not good". Pulled the rest, and the CPS is COVERED in it. I ended up busting my middle timing cover (of course) in the process too.
I couldn't figure out where this dust was coming from - I mean, it was obviously in the timing area, the T-belt was coated in it & everything. Well, I go to re-align the crank into position to reinstall the belt, and WHOA BABY! The Woodruff Key was mangled, half worn away, and the crank relief area that accepts the key was just as mangled. Faced with almost certain temptation, Sir Galahad rushed back into Castle Antrax to give the 8-score young blondes & brunettes their spankings...
Seriously, I weighed the options, had Woodruff Keys on the shelf, had access to a 3.2L (yet to be pulled from the car), have enough crud to build about 4 3.0L engines, and have a crank sitting on the shelf (from Mark N.). Since I've got the 95 ATX coming in about 2 months or so, I decided to jam a new key in there, and see how far I could get before it totally shreds. At that point, the 89 will likely just get a 3.2L swap before I sell her.
Thought I'd post it - watch those Keys when you do a 60k - make sure they're in good condition.
