dcmeigs
I have two leaks that I'm trying to fix.
The shift linkage has a u-joint and that connects to a rod at the transmission housing. It has a boot over it at the housing. I suspect that oil is leaking there. Is there a shaft seal there and can it be changed with the transmission in place?
On the back of the oil pan there is a fitting above the drain plug that is leaking oil. It has a wire leading to it. I assume that is the oil low-level sensor. Is that correct?
Thanks for the help.
Dave
Dave
