masho95
got Zex?
How do you pull it out the bottom?
drop the subframe with the drivetrain attached. The way I did it was to unhook the engine wiring from the body wiring, unhook the ball joints & tie rod ends, unhook the axles from the knuckles, unhook the cooling system, unhook the exhaust, unhook the A/C and wire tie the PS reservoir to the engine. I then put 2 1000lb appliance dollies under the subframe and lowered the car on to them. Undo the 4 subframe bolts and the lift the body off the drivetrain and roll it back over the engine.masho95 said:How do you pull it out the bottom?
