Endlinks for a '98 SE
SHOtimer
#2910
Santa Clarita, Ca
I'm driving our family '98 SE while I do some motor work on my Gen II ATX. It has some noticeable clunks in the front and rear, which upon inspection I have found to be worn endlinks. The car is just shy of 70k. Will rear endlinks for a Gen II fit the rear? Also, I have been shopping around for front endlinks, I am not getting plastic ones. I am either getting the Windstar aluminum ones, or the MOOG steel ones. The MOOG are a pit more pricey than the windstar though. My question with that is, will the Windstar fit a Gen III SLO as it does the Gen II SHO?
Thanx, Doug
Dylan
Central NY
I belive all the rear and front endlinks are interchangeable from gen1-3 and maybe gen4 taurus's. The moog fronts are greaseable are the windstar ones greaseable??
I have rear and front endlinks on my 98 SE that are for a 91 SHO.
Mr Anonymous
Tire Wall
Front endlinks between gens 1/2 and 3/4 are NOT interchangeable. Just look at them and you'll see the difference. Thus, the Windstar links will NOT fit.
The rears are fully interchangeable.
SHOtimer
#2910
Santa Clarita, Ca
Oh, well I guess I won't be using the Windstar endlinks. The steel MOOG ones get pretty good reviews from what I've heard, I guess I will go with those.
Thanx, Doug
Dylan
Central NY
NOw that i have looked at them, the gen1 fronts may not work with the gen3 front. The angle of one end is different by about 45 degres. But I will be useing a gen1 bar so hopefuly (for me) the bar has a different angle than the gen3 bar and hopefuly the endlinks will fit the gen1 bar on my gen3.
Mr Anonymous
Tire Wall
Let's try this again... Front endlinks from a Gen I or II (1986-1995) Taurus, SHO, or Sable CANNOT BE INTERCHANGED with front endlinks from a Gen III or IV (1996-2005) Taurus, SHO, or Sable. The difference is in the length of the endlink, and how the endlink attaches to the strut.
The only way it could be done would be to install Gen I or II front struts in the Gen III or IV car, which is highly undesirable due to the different front-end geometry of the '96 and later cars.
Dylan
Central NY
I went out and took off one of my stock (plastic) front endlinks off my 98 SE and matched it up with a 91 SHO front endlink (moog) that I bought from rockauto.
One is about an inch longer than the other but, that's not what i'm worried about, maybe I should be :shrug:
And you can see the angle at one end is different the one of the other ends.
As far as it being to short or long, (by about an inch) I would think (and hope) you can just chnage the nagle of the swaybar a little before you tightin down the bushings. And maybe the angle of the swaybars are different too :shrug: .
But since i allready have them I might as well try them out.
http://www.supermotors.org/getfile/185114/fullsize/endlink comparo.jpg
Mr Anonymous
Tire Wall
Yes, you should be worried.
Yes, I know.
I personally can't understand why not just use the proper endlinks with the proper car. A set of Gen III/IV front endlinks is less than $50 at most places and are certain to be the proper length and orientation. Perhaps you could use a torch to re-shape the Gen I/II front endlinks or perhaps do the same to the swaybar or strut.
Best of luck with that!
