Endlinks and bushings....what do i need
TwiceSHOwn
Atlanta, Ga
Can some one tell me the part numbers of the fornt and rear sway bar end links. Also if i am changing sway bars then what else do i need to replace at the same time..bushings etc?
THanx
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
TCE SHO stopper brakes
Due for its 60K sigh...
bigsho
sterling va usa
I did the rear ones and I would go with heavy duty endlinks. I ordered mine from sho shop. You also need grease for the bushing just make sure you put enough on them.
Robbie
95 MTX red
SS SNORKEL
24 and 26 sway bars on floor
hanshua
Blue Mounds, WI, USA
If you are upgrading to a larger swaybar then you'll need new swaybar bushings to fit the new sizes (2 front and 2 rear.. get the greasable front poly bushings) and then for the endlinks when you order a par of endlinks, it comes with bushings...
go to shonut for this stuff... good prices and exelent service http://www.glen-net.ca/shonutperformance/
-Justin
95 ATX
K&N Silencer-Coneless, SFC's, two 12" kenwoods w/ 600watt amp and sony CD, CincySHO Cowl Hood, Removed secondary silencers, TPR bushings.
Comming Attractions: New 17" wheels (need rubber for them), SS y-pipe, new springs to fix my sagging rear, 24/26mm sway bars, Strut Tower Braces, Yamaha Badges :)
