kitts95
Ah,where to start. I live in illinois and took my 95auto to pass smog which of course, it didn't.I failed HC(.80 allowed,1.23 actual)no check engine codes at all. car runs good and strong.Took infrared thermo readings on cats,Inlets were 500 degrees,outlets at 380.Everyone said cats were bad.Got a system from sho shop in cali.,changed thermostat,plugs(all were clean),changed oil,two cans of heet in tank to remove moisture.So now the car seems to run stronger,I took it back for a second round,It is puking out more HC(.80 allowed,2.40 actual).The CO is up from the first test(7.4 up to 12.5)but that is still passing in my great state.I took thermo readings on these cats and the inlets are 330 degrees and 320 on the outlet.the car runs between the a and l on the temp guage. I think I covered and bored you guys with my problem enoughso if you have any suggestions I would appreciate it.
