EMERGENCY - PLEASE READ AND REPLY - THANK YOU!
NORMAN
FL
Hey all,
My friend's '89 SHO has been down for a month..
He broke his halfshaft carrier bearing, and he cannot find a replacement part..
I am not sure if that name is the correct name of the part, but it is that shaft that connects the transmission to the passenger side CV shaft..
Where could I find one this week, and for how much?
Please reply to [email protected], as well as here on the forum..
Thank you very much!!
Norman
'99 Cobra (got it two days ago, and I love it so much already)
'93 SHO
gregr
Orange County, NY - USA
Call SP Motorsports. I got a rebuilt one for about $125.
Good luck!
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
jthomas68
Area 51
I went thru the same thing this summer.The bearing freezes and rips out the bushing.I called Ford Customer Service and the gave me some places to call.It was a long process,and i even got the wrong part 1 time.Let me know if you don`t come up with anything,and i`ll go thru my notes.The part is Obsolete.
Jeremy Thomas
Modified 91+
gregr
OOPs! I thought you meant the halfshaft. The carrierbearing is obsolete. I remember Jeremy sayiong that. Sorry for the mix up.
Greg Raciti
SHO Forum Webmaster
24mm front sway bar
26mm rear sway bar
poffffd
