emergency brake light
nutorious_sho
MN
So I ripped out my e-brake when I replaced my rear brakes and now the the e-brake light is on and wont turn off (go figure).
Anyone know how to get rid of it besides black elecrical tape?
jelloslug
Digital
Greenville, SC
Your going to have to do somthing about the parking brake switch. That's why the light is on all the time.
nutorious_sho
MN
FYI
my e-brake pedal is pushed in forever incase I ever decide to fix it.
I pulled it up to make contact with the trigger with no change in the light. Isn't there just a wire I can snip??? anyone.... anyone....
30footSHO
In da mountains
Boise, ID
Exactly why did you not replace the E-brake? If it's not on there, chances are you won't get the light to turn off. Not to bust your balls, but ripping out an integral part of the system is a bad idea.
rangerj
Brunswick, Ohio
You may want to check your State motor vehicle code to find out if it is legal to drive on your State's roads without an emergency brake that is operable.
The emergency brake is a safety device and most states require that it be in operating condition. Your insurance company may also be concerned about the fact that you removed a safety device.
If you are just driving the car on a race track, and not on public roads, then you should be OK. If you are driving on public roads, then you should become familiar with the legal terms "negligence", "willful", "intentional disregard", and civil and criminal liability. rangerj
nutorious_sho
MN
I apreciate the concearn by all, but this was not my question. I'm not that interested if it were legal or not. if I weren't going to be doing anything illegal then why did I buy a SHO :shrug:
Just my 2 cents but I had an older '92 SHO where I was in an accident because I couldnt stop, and the the last thing on my mind was the e-brake.
Anyway back to my original question - what can I CUT to get rid of the light...
rangerj
Brunswick, Ohio
When the e-brake pedal pushes against the switch it breaks the circuit. So, tape or wire the switch in the "open" position and the light will go out. Then when you are ready to restore the e-brake you will not have to repair the circuit. You could also wire or tape the pedal in its full "up" position which would also push the switch into the "off" position.
Best of luck, rangerj
30footSHO
In da mountains
Boise, ID
Some systems use the brake light to alert the operator of problems with the system. My old Camry did this, as did our old Voyager, and my '93 would turn on the light when the fluid got low. Not having your e-brake available to the system might be part of your problem. This is what I am getting at when I say it is a bad idea. You could be eliminating a safety device, namely your brake warning light. Now it's crying wolf and you might just find yourself in another "can't stop" situation.
nutorious_sho
MN
Aw I see, didnt think about the antilocks :doh:
I Tried bringing the switch back up manually but the light stayed on, anyother suggestions, or location of wire (I can always soilder it back together later)
Thanks
30footSHO
In da mountains
Boise, ID
Your ABS has a light all its own. For the amount of time you will spend trying to disconnect a wire, you could just put an e-brake back on the SHO.
FWIW, my e-brake light would stay on constantly because the pedal stopper was misplaced. I got used to it. Other times I just kicked it up good and hard so it would sometimes stay off all day.
MelectroK
Michigan
Unpluging the wire from the top of the ebrake switch will turn off the light if that is the reason it is on.
danny gorgo
ny
you could pull the light bulb out. all you have to do is tak out the intrument cluster and remove the bulb.
Dan
nutorious_sho
MN
I appreciate the thought, but have you ever tried to pull that thing out???
its a pain!!
looking for simple solutions.
thanks
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
thanks
Simple solution;Spend a few buck's and send it to a repair shop if you really want the light out.Why leave it half a**? :shrug:
If the light didn't go out when e brake switch was unplugged(single wire that plugs to white plastic switch on the top of the e brake assy),ever look at the brake fluid level?
Later :thumb:
nutorious_sho
MN
I would like to send to repair shop, but I didnt send it there in the beginning nor would I like to know for the same reason. Repair shops cost money, If its not critical, its not going.
I will try unplugging the wire in the next couple of days.
Brake fluid is fine.
Thanks again
