Emc problems
Natemc16
Omaha
I just bought a 1990 and have been working on the electrical and noticed the ecm is missing. I ordered a new one and the connector and housing is missing as well. Looking for advise on where to source these parts and any knowledge on some connectors in pictures. Thank you
Is that to the abs module? I think those are both part of abs system. Been a long time since I've seen that stuff
Natemc16
Omaha
Thank you I will check it out. Alot of the electrical components are missing so I'm scrambling trying to figure out what is gone.
Is the antilock brake system block still there? I wonder if it was just unplugged or bypassed it and/or removed it.
Here is the electronic part and you can see where the plug goes
There is also a block where the brake lines come in and out with solenoids. I'm not sure if this is a direct replacement, but you can get the general idea from the plumbing input/output etc
Natemc16
Omaha
Thank you much that is exactly what it is.
Natemc16
Omaha
Thank you much. I am now trying to get power to my fule pump and sending unit.
