Electrical problems :(
SHOJosh913
SHO member
Spring Hill, Florida
No interior lights, no under hood light...massive battery drain. Horn still works, door locks dont work...when using the door lock switch the lights on the acc unit come on. Also car wont come out of park. Any info on this? Is this a major electrical problem? 1993 ATX
Sent from my LG-D851 using Tapatalk
TimboSHO
Intermediate
Wyoming, MI
Try pulling fuses one at a time to see if you can isolate the circuit that's causing trouble.
as I recall, the trans shifter interlock requires the brake light circuit to power it to release. my guess is you have no brake lights, therefore it will not shift out of park.
you have a short somewhere, and you just have to trouble shoot it one circuit at a time to narrow it down.
SHOJosh913
SHO member
Thanks guys! I did notice that i left my passenger rear window cracked over night and it rained. But nothing was wet this afternoon so idk of that could be the cause. How would i go about troubleshooting this? Just start pulling fuses and see if the symptoms go away?
