So i have a problem.
I am going to be going through my 3rd starter.
There is OBVIOUSLY a reason why the starter is drawing much more power than it should be - causing the internals to fry over time.
We have measured the voltage drop from a battery terminal to the wire.
Its using all the voltage available... of course... this is not a good thing.
When we have everything connected like normal - and we measure the voltage across the battery we get 0 volts. But when we disconnect the starter we read the standard 12v across the battery.
We traced the problem to the fuse block under the hood.
With measured the wire across the fuse block and it uses all 12v. After taking every fuse out of that fuse block... we still have a voltage usage of 3v. This doesnt make sense. If you take every fuse out of a fuse block how can it still be using voltage (unless it has a short to ground)
When the headlamp, EEC, and FUSE BLOCK mega-fuses are put in, the voltage usage spikes right back up to 12v FOR EACH OF THEM. If someone could disconnect that wire from the engine bay fuse block and measure the voltage usage across it with KOEO, that would be great.
Nothing is making sense...
If we are using all the voltage available... and shorting to ground, we should be blowing fuses of at least some size, in the car or under the hood.
--- We are going to take out all the interior lights (because they do not work) and see if that 3v changes at all. This could indicated a Short To Ground in the interior light circuit. But that would still not indicated the 12v usage for the headlamps, EEC, or Fuse block circuit.
Answers ASAP would be very helpful seeing as how im stuck about 2 hours away from home - And the probability that i will have to pop the clutch to get home since the starter cant get the required voltage (not to mention the starter doesnt have enough juice to start the car)
