avatar28
I was sitting in my car with the engine idling to keep the heat going. No warning lights were on and the car was running fine when it suddenly stalled. I tried to restart it and it cranked for about 4 seconds and then lost all electric power (everything, no lights, no chimes, nothing). I tried moving the battery cables and it doesn't make a difference so I'm doubtful it is them. Anywhere else I can check that might cause a total electric power loss to the vehicle.
I have problems with what I believe to be the camshaft position sensor and I had a bad battery. One thing that would happen with the old battery is that when cranking it it would just lose almost all electric for a moment and then resume cranking. I replaced the battery this morning (it was colder and that was all she wrote for it). It's been working fine all day (other than starting issues caused by the cam sensor) although I still had a couple of instances with it momentarily losing power when starting. Oh, I have a bad tstat so this is the first time I've had it to full normal operating temp in quite some time. Not sure if that's relevant.
