Electric fuel pump replacement
greg geraci
Huntington Beach
If any one is familiar wth replacing the fuel pump..... I just replaced mine and I didn't notice at first but I had a wire with a push on connector along side of the wire loom for the assending unit that plugs into the top of the fuel tank.
For the life of me I can't find any where to plug it into. It only is about 6" long and in the surrounding areas there is no terminal for it. All I can think of is it is extra?.......... Any one know?
thanks
greg
TYSHO
Earth
If it's an "L" shaped end with a rubber boot, it plugs in right beside [to the passenger side] the big connector on that little stud that is threaded.
Edit: Make sure you didn't break that stud when removing the connector, maybe that's why you can't find anything.
greg geraci
Huntington Beach
hey ken,
Are you famiiar with that extra wire, I can't seem to find a place for it to plug into . Some one else said that I broke off the connector where it plugs onto but no way did I screw up the Main loom connector or any where near that.
greg
TYSHO
Earth
Give me your email and I will go outside and take a picture and show you the wiring, there's no extra wiring around there unless someone tapped in some wires.
greg geraci
Huntington Beach
Pics for gas tank.
[email protected]
Thanks for taking the time with the Pic and all. I don't think I broke any thing off. I looked real good and didn't see any thing tht resembled where I could of plugged it in to. But it sure would help if you could send me the pic
Greg Geraci :wave:
TYSHO
Earth
What year is your SHO? I just took a look at my 93 and it does not have what I mentioned, I think this is the Gen 1 set up. Also, my 93 didn't have that wire coming out the harness like the 89. I'll send pics shortly, after I upload them! :thumb:
TYSHO
Earth
Pics sent...
I just did a search and came up with you having an 89 SHO. Seems like someone swapped tanks on your SHO with the fuel pump mounting plate [gen2 style], or just the plate alone, therefor you have no where to put the connection.
Let us know! :thumb:
bmytych
