SHONUT91
My codes tell me and that damn check engine light gleaming in my eye.That my egr valve is the culprit. My question is why? The reason I ask is because I have checked and cleaned the intake manifold and nostrils I have also checked the EGR valve doing the engine suck method. I have also checked the vaccum lines and all attatchment tubes to the exhause manifold. Yes I have cleared my keep alive memory. The check engine light only seems to come on when the outside temperature is above 50 degrees. Now onto my idle problem. My idle wants to stay around 2000 RPM. I have checked and cleaned the IAB valve have also checked TPS. The only time the idle even acts normal is when I first start it. It will idle down to normal until I start to move. Any help with these problems would be greatly appreciated. Thanks shoot
