Black-taurus
I decided to check the engine codes on my 90. I came up with an ok (11) for the kieo but then there was 19,91 stored? THen with the engine running it came up with a 77? (failed goose test WTF) then the test I was sure I would pass the cylinder balance it gave me 30 and 40 for so cylinders 3 and 4 are bad apparently? the engine idles fine though. what does the cylinder balance test? what does it mean? i know the valve cover hex bolts or whatever those are squirt out oil and the valve covers are leaking like an M'Fer. could this have something to do with it. Also I am getting a weird noise from the timing cover I have to investigate. Could this be related (bad cylinders because of bad timing????? Thanks very much
Dan
Dan
