EAVC
Doug Waschenko
New York
I had the EAVC control head replaced at the dealer and it will only blow at maximum speed.
Before I go pulling the unit out does this sound like a "control head" problem.
These things aren't cheap to replace on a whim.
Has anyone taken the unit apart and replaced just the fan cntrol switch in the unit?
BlackOnBlackATX
Dutchess County, NY
i think your problem is the blower control module, not part of the EATC head, and as far as i know its fairly easy to replace. in fact, if i remember correct its right behind your glove box. this is a common problem though so you should do a search in the past posts to make sure im correct on this one, or maybe someone else will chime in. good luck!
