EATC bulbs
JoesSHO
Reality
I just pulled some EATC bulbs from the boneyard over here, but they are out of a soft-button EATC, and seem to be quite a bit taller than the "shorter" bulbs in my hard button EATC. Can I take out the bulb, and replace it into the old housing, or is the bulb going to be too tall and melt the button?
I don't think the bulb as it is will work, the wire connectors are in different places.
Anyone done something like this?
Thanx!
JoesSHO
Reality
Uh...
Uh... No? I said that the bulbs I took out were from a soft button EATC. All of the buttons were pushed in...
Hopefully, I'm intelligent enough to take a hard button EATC if it was there...:oogle:
I'm going to try a transplant tomorrow.
Markus
Ottawa, Ontario, Canada
Thanx!
The bulbs are not interchangable. I recently purchased a bulb for my 95 EATC and it cost me about $15 Cdn from a dealer. Do a search for a post I recently made to get the Ford part number.
MorpheusGPR
Ford TRIO
Indianapolis, IN
I just paid a fortune for a hard button off ebay but the thing is super nice.
I am happy about it, however I would like some tips on swapping it out...i.e. how do I get the stocker out?
JoesSHO
Reality
Plug 'n Play
Assuming it is a SHO model display, it's a plug and play thing- pull the trim off, unscrew the old one, unplug it, and yada, yada, yada!
I've got the part numbers, I ran a search for them. Thanx!
Minnesho
i was wrong
MinneSHOta
it will only work if its from a Taurus/Sable. the lincoln units and other units from expeditions etc are not plug and play without modifications....
JoesSHO
Reality
Well,
I smell an Ebay relist brewing...
They are modifiable (if that is a word) but may be more work than you'd like. Some on the forums have them.
Good luck!
etc1006
Baltimore, Md.
There 'may" be a way to use LED's... I used to be on a Ranger forum and they were using LED's to replace the bulbs in some of the places you wonder why Ford even did a bulb in them... For example. IN the headlite ****, in the window switch, I didn't even know it was supposed to be lit til I read the DIY on using these LED's.
-Eric
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
well if you do get interested... I am on another forum with the same handle... www.hidplanet.com/forums
try that out, you may find yourself with new ideas with leds/hids....
the reason LEDs prolly weren't used back in the day so much, is because they weren't utilized as well, and the higher powered LEDs haven't really showcased till a few years ago.
MorpheusGPR
Ford TRIO
Indianapolis, IN
This weekend I am going to try and get my shifte o/d button fixed and put back together and take my EATC out and see if that one I bought will match up, I hope it does.
etc1006
Baltimore, Md.
Cam, I was mentioning for a replacement. I realize LED's aren't new, just the technology that they keep advancing with them is incredible. That way chances are you won't have to deal with it again. I chack back on there once in awail and they are always using them for more and more small bulbs that are a PITA to replace (like dash lites).
-Eric
Camarok
Eric, sorry if it sounded like I was talking down to you, i wasn't, it was just how I meantoned it. I was kinda meatoning how they should have back in the day (gen 1 & 2 sho days) used them.
ah well, i gotta go to work
PEACE!
JoesSHO
Reality
Hay!
What the heck? This is my thread!
Just kidding! :biggrin:
(I was bored)
