easiest way to tighten e-brake?
SHOtimer
#2910
Santa Clarita, Ca
Yes.
Their is an adjustment right under the front of the rear driverside door. Slide under the car and find where the two E-brake cables meet. They come together at the adjustment mechanism, if you tighten the bolt on the stud it will tighten the cables, if you loosen it, it will put slack into the cables. You don't want them tight enough to be grabbing the rotor, but you want a small tolerance.
Doug
TheKrazyRaven
4 8 15 16 23 42
Lawrence Massachusetts
SHOtimer said:
Yes.
Doug
:thumb:
TheKrazyRaven
4 8 15 16 23 42
well the nut was rusted in place and wasent going anywhere
so i got a split washer, opened it up, put it behind the nut and then closed it with a pair of plyers, works awesomely now
SHOtimer
#2910
Santa Clarita, Ca
Glad to hear it worked out. Makes me glad I live in Cali, no such thing as 'rusted in place' here....
Great inventiveness.... :thumb:
Dr. Tweak
Mad Scientist
Northern Vermont
I just replaced both of the rear cables and let's just say that my angle grinder came in handy... several times... :D
91 SHOplus
Sholess 4 Now
North Jersey
TheKrazyRaven said:
well the nut was rusted in place and wasent going anywhere so i got a split washer, opened it up, put it behind the nut and then closed it with a pair of plyers, works awesomely now
Great Idea, Steve. I'll have to do that to mine.
