TheKrazyRaven
4 8 15 16 23 42
SHOtimer said:Yes.
Their is an adjustment right under the front of the rear driverside door. Slide under the car and find where the two E-brake cables meet. They come together at the adjustment mechanism, if you tighten the bolt on the stud it will tighten the cables, if you loosen it, it will put slack into the cables. You don't want them tight enough to be grabbing the rotor, but you want a small tolerance.
Doug
i hate rustSHOtimer said:Glad to hear it worked out. Makes me glad I live in Cali, no such thing as 'rusted in place' here....
Great inventiveness....![]()
TheKrazyRaven said:well the nut was rusted in place and wasent going anywhere so i got a split washer, opened it up, put it behind the nut and then closed it with a pair of plyers, works awesomely now
