Sleeper
Wow! I sure like working on trucks a lot more than working on cars! Anyhoo, I just finished replacing my timing belt, front and rear mains, VC gaskets, plugs, wires, thermostat, clutch, TOB and passenger axle. When I started it up, I had failed to tighten the PS belt idler nut. I heard a grinding and saw that the idler was sitting on the stud at an angle and the bottom of the pulley was scraping against the bracket. The nut and washer had fallen off. Does that make sense? Anyway, I tightened the nut and started her up again, and now the PS pump sounds like it's out of fluid. It doesn't noticeably change sound when I move the wheel. I've put 140 miles on it, no changes. PS works great. WTF? Does this make sense to anyone? There is plenty of fluid in the reservoir, and I can see it "flowing" in the reservoir. I'm puzzled. I am about to drive the car 900 miles across country and give it to my dad, so I need to have it reliable. Any ideas? Should I just replace the pump and hope it goes away? Since it works great, I'd like to figure out what's going on. Could I have pinched some hose when I reinstalled the subframe? Grrrrr. Let the ideas flow.
