gmail
Well-Known Member
I know, I just brought it up because gmail made it sound like a SHO won't detonate, period.
considering it says premium recommended on the gauge i think im still right
until someone on here can prove without a doubt a N/A SHO thats maintained (im talking running good fuel, plugs etc) is DET causing it to make the rod bearings fail why keep trying to say im wrong...
the rod bearing failure in these cars is not related to DET
from everything i had gathered over the time i researched it was related to OILING the system flows more oil then the filter recommended by FORD can with a motor built to such tight specs and a filter media only filtering in most cases 10 microns.
you relise most engine wear happens in several conditions im sure 90% of these rod bearing failure engines see everyday.
i had read before that in most engine when its colder then 180 degree twice the normal engine wear happens.
at temps at or below 140 its 4 times as much engine wear.
metal dirt or any material as small as 2 microns can cause a good amount of engine wear and the tighter the specs on the motor the more wear that can result.
oil that goes way past its life or cheap oil without wear inhibitors etc.
these are just naming some things that cause failures.
im a firm believe the filtering system in these engine is the main problem, the filter not flowing as much as the oiling system and the filter not being able to filter what it should is the biggest cause in my mind of failure.
i also feel the stock idle is a bit low the PSI on most of these engines at idle is 12 psi give or take some.
draw your own conclusions but these motors arent failure due to DET if your lucky maybe a handful of these engine n/a ever see DET.
like i said im not trying to be rude to anyone so i would think this would go a lot smoother if you dont try and act rude to me.
