Drove a 93 ATX today, and I have a question....
SHO SPD
SHO member #480
Naples, Florida
I noticed that when I shifted it anywhere whether it be from park or into park, I needed to push the shifter with a pretty firm push, now I know that they shift into drive and all the other ones easy, and you can feel it go by the gears, but with the button in, I have tp pull or push it with a pretty firm effort, the tranny has 120k and never been replaced, could this be on its way out? It shifted smooth in all the grears.. and also the steering wheel shakes bad when on the brake.. rotors?
Matt
1989 Titanium
ITS FOR SALE!!!!!
e-mail me for details, would like to sell SOON.
93nighthawk
Mitchell, SD
Hi Shospd,
My '93 has done the same thing sense I bought it at 55Kmi. I think it might be a safety feature and it is the oem tranny. (so you don't go into park while you are doing 6500rpm in reverse?
) As for the front end shaking, I would say that it needs a good front end aliagnment (from personal experience) instead of rotor's. It does not take many *** holes to get it out of wack.
Eric
'93 Green 'NITHAWK' ATX
120K MI, Fish tank ligts, Sho Shop Y Pipe, Sho Shop SFC's, Removed Silencer, Sho Shop 60K, Replaced Motor Mounts, New EGR/PFE
'78 Green/White Bronco C6 AT
200K mi+ on body, 30Kmi on engine, 351M, 4brl Edelbrock carb, Edelbrock intake, duel exaust, lifted, rusted to **** but can go anywhere...
'95 Mercury Mystique ATX
110K mi, 2.0 I4, studs, Great parts getter for the other two vehicles.
40' x 40' heated garage to work on all 3 :D
T
Tommy the Greek
Guest
If the steering wheel shakes when you press the brakes hard @ 40 mph + you definately have to resurface the rotors or get new ones.
If you do get new rotors I would suggest you do the '96 brake upgrade mod.
'95 SHO ATX, 55W foglights, coneless, fishtank mod, white/mocha cloth interior, 48K, Mobil 1 10W-30, build date 12/13/94. 60K service performed on 12/21/01 @ 46,043 miles due to a leaking w-pump. (grrrr)
Below is a pic of her @ 37K miles (July 2001), overlooking the Long Island sound off Orient point, NY.
www.roushind.com
AIM: kalamos73
ACV1081
Member #187
IA US
Not for sure exactly what the tranny thing you are talking about entails but I may be better suited to answer after talkin to you on im sometime... the braking sounds like rotors to me & for like $19/each I believe you can get new ones according to Scott(sdpatt) he's only went through probably 15 pair
Other than that I'd say you're definitely taking a risk if the car has 120K on the clock & original tranny but seems some are just workhorses while others are like my own
By the way gauges are on.
The fleet: 1012264997459 123
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 135,000 miles(Fresh 60/100K THANKS SDPATT!), 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 225/55/16 Blizzaks WS-15's on slicers for winter duty, 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads, SHOSHOP Stut tower braces(front & rear). GTECH times 0-60 in 6.92 1/4 15.3 @ 98.4.
Not yet installed: poly bushings... Upcoming: Well you could just say I am on hold since I bought a gen.1 now.
New to the lineup: 1991 White MTX- 122,000 miles, recent 60K & clutch, CINCYSHO cowl hood, K&N filter, rod shifter, dynomax catback, SHOSHOP y-pipe, & white slicers w/ 225/50R16 Dunlop SP Sport 8000 tires(Being sold & replaced :p . Too bad she'll be sitting till spring cause I'm not driving it in the salt & sand. Website with pics from previous owner: http://www.homestead.com/SHOIOWA/SHO_Spring_2001.html
Porod
Green Bay, WI 54301
I have a 93 atx and the shifter does seem fairly stiff to me, but mine is the only SHO I've driven, so the validity of my opinion my be somewhat limited by experience (or the lack thereof)
Jersey Fred
Medford, NJ
I've had two ATX's and they both required a little effort to pull into/ past reverse. Since you need to depress the brake pedal to get it in gear, sometimes it helps if you wait a second after pressing the brake.
Just my two cents worth....
Brad kirk
