Driving me to drink'in!!!!!!
Vito117
Iowa
Im having serious idle speed problems here guys!
OK...a while back I put in new battery.
I did the reset idle thing to no avail. Still stalling and low RPMs
Then I removed the IAB and cleaned it....did the reset thing....folowed reset instructions to the max.....still same old crap!....low rpm's....stalling.
Now my check engine light comes on once in a while.
I have to run the car with the AC on to keep from stalling out at stop lights.
OK.....now what???? UGGGGGGGGG
Vito117
Iowa
OOps....sorry forgot this:
1993 ATX
120k
with a dying out tranny to match
Ummm... have you tried replacing the throttle position sensor? Cleaning the IAB will not always cure its malfunctioning. It may require replacement.
Look into the speed sensor as well. It may affect your idle.
It affects idle only if the EEC-IV detects that the car is in motion (via the VSS).
Run the codes and post them.
The KOER test makes a check of the ISC and will tell you if it doesn't like it.
BigSHO43213
Ohio
I also had the idle problem and I replaced the throttle positioning sensor and the Barometric absolutte pressure sensor and that solved it. Good luck keep us posted and stay away from the liquor cabinet its mine!!! thumbs_u beer beer beer Terry G.
Vito117
Iowa
OK......so where are these 2 items located?
And can I get them at Autozone...or?
Try the throttle position sensor first. It is located on the side of throttle body. It should be black with clip on wire connector. You can get this at Autozone and it's not very expensive. It is internally spring loaded so when you install it have the connector end at about 2o'clock and turn it to line up the screw holes at 3o'clock. Careful with stripping the screws. If this happens the replacements will probably have hex heads instead of phillips head.
BigSHO43213
Ohio
I bought mine from a dealership just because I thought I got a better deal but that was only because I have a friend that works there so you could probably get them from Advanced Auto Don't deal with Auto Zone their stuff is junk or the stuff I bought for my SHO was Or you can probably look on the internet for 'em like on e-bay or somethin or try here maybe they can help ya
www.fordpartsnetwork.com Good Luck Keep us posted
shoot thumbs_u burn_out Terry G.
