Driver door won't stay open on hills...
Push the door to the fully open position and rotate the round roller that presses against the rubber backed plate in the door jamb to a new position that doesn't have a worn rut in it.
<small>[ November 05, 2003, 01:16 PM: Message edited by: sdpatt ]</small>
Ptatohed
S.D. CA
sdpatt:
Push the door to the fuly open position and rotate the round roller that presses against the rubber backed plate in the door jamb to a new position that doesn't have a worn rut in it.
Thanks sd, I'll try that tonight. :)
DHMag
Free At Last
InCahoots, Texas
MO-KAN SHO:
Nah... just weld the doors shut, wire the power windows to a remote and get in/out Dukes of Hazzard Style... No more door problems... :p
hahaha..."Hood sliding like Bo Duke...What Was I Thinking"
Ptatohed
S.D. CA
Guys, don't quite you dayjobs for comedy wink
sd, I tried the roller...with no luck.
If you look close there is a light grey rubber wedge that works with the door roller/hinge. I am going to try to wedge some more rubber in there.
Thanks everyone. :)
crystizel
