Driver door issues
362104
DV8
43*46'30"N 88*26'41"W
My driver door makes this "creak" sound whenever I open it. Also, it won't lock in the 1/2 way position. It should hold in that position like the passenger door. I'm sure the mechanisms in the door are shot. It's a 94. What need to be done to repair it? :salute:
Keith
Storm-Chaser
Shit Louis
Purportedly (-2 sp), you can remove the pin in the lower door-hinge and replace the hard-rubber roller - but you're going to have to remove the entire door. Dorman sells/sold a replacement pin/roller kit.
You might find it easier to simply replace the entire door hinge; or get a used door hinge at a salvage yard, replace the pin/roller in the spare hinge, and then remove and replace only the lower hinge.
hawkeye18
Sorta cares
Norfolk, VA
you can also squirt some grease into both hinge assemblies and the roller assembly with a grease gun; that's what I did when mine started to creak, and it hasn't creaked since.
Storm-Chaser
Shit Louis
But the reason the door fails to stay open, is that the hard-rubber roller on the lower hinge deteriorates over time and one or more depressions/flat spots form, which prevents the hinge from working correctly.
If the door will not remain open, the either the roller or the hinge assembly itself need to be changed.
Storm-Chaser
Shit Louis
I ran across the Dorman kit last night on RockAuto's website - Dorman part number 38350.
Look under the category [+] Body Exterior, subcategory [+] Door Hinge Roller
I have seen the Dorman/MotorMite kit available in-store at AutoZone and Advance Auto, it's on Murray's/Parts America's website, and probably also available at O'Reilly's and others as well.
