Drag Racing a 2015
subframe
New Hanpshire
This may have been asked before but I can't seem to find it....Should you be in drive or sport on the trans....I understand on the tires 26psi up front, 28psi out back, turn off traction control, launch at 2000 rpm tuned, 2500 rpm stock...does this sound about right?.....Rich
BigB15
GA
I run in Sport with traction control completely off. I have read that it doesn't make much of a difference because your on the floor all the way down the track.
I would avoid trying to use the paddles, Sport shifts either way.
The traction control makes a difference.
I had much better times launching at 2000rpm, at 2500 there is actually wheel spin.
dillion major
What have you guys found best to launch from in a roll race
BigB15
GA
That is a interesting question. Why Roll race a AWD?
I would suspect that the middle of 2nd gear or around 2500-3000rpm where torque is at its highest.
dillion major
Because my two best friends have a g8gt and the other has a 1le track pack camaro and we roll race all the time where were from so I was just wondering cause I couldn't really find a high boost spot when roll racing
dillion major
Okay thank you I ran some passes in London dragway in London kentucky my fastest pass was a 14.125 an the car is completely stock I was launching at 2000rpm
Stock, you can try launching between 2200 and 2500 rpm. Tuned, more than likely 2000 or just below is your best bet.
SHOnUup4
SE MI
Brake boost!!!
I've done a few rolls...
Paddle into 2nd gear, get slightly on the brake and full throttle around 40 MPH. Three honks of the horn come off the brake and get instantly planted in your seat:boink:
Haven't tried this technique, may give it a go next time out on Woodward where all anyone wants to do is roll race. It'll be tough for it to do better than the ecu dropping car to 1st and screaming off though I think.
Rich
13blacksho
Des Moines IA
I thought the same thing...
But this way as soon as you dump the brake pedal you are at full boost and mid power band
shoblock
Cleveland and Naples
I come up to the line in 'D', powerbrake to about 2200. When the last yellow light comes on, I floor the gas, sidestep the brake, and wait for the finish line. 13.7-13.8 ET every time in 58 to 64 degree temperatures. Fun, even when your old.
BigB15
GA
I tried that but got 12.83
