Doing a 60k
Corby
Porsche Eater
Hey everyone, I just got a 95 mtx with 110,000 miles on it and have no clue whether or not any maintenance has been done to it, i changed the oil and was thinking about doing a 60k to it. Does anyone know of anyone who knows how to do it and how much it would cost and whether or not its worth spending the money on, it seems to be running fine other than it only gets an average of 18 miles a gallon. Thanks for any replies!
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
To do the 60k you just need to do the valve adjustment, plugs and wires at a minimum.
Most places wont do it or will charge you $1k. I can do it and it is quite easy. SHOBros will be offering shims kits so you can do it soon. If you can do it yourself it is very much worth it.
Corby
Porsche Eater
Thanks, i heard you can buy a video to help, i just dont know what kind of tools are needed.
LOUDSHO92
Sponsoring Vendor
Some SHOs need the valves, other dont. It really helps to do the the pulgs and wires as well as the valve cover gaskets.
To do the valves you need the valve adjustment tools and shims.
The water pump is more of a preventive maintaince that doesnt always need to be done.
Corby
Porsche Eater
Thanks guys, i just want to keep it running for as long as i can, is there anything else that can be done to keep it in good running shape, or is it a repair it when it needs to be fixed kind of thing?
SHObill
'The Collector'
Rochester MI-48307Detroit
If your only getting 18MPG I would check your codes for O2 sensors,they should throw a code. Or could be fouled plugs &/or bad wires. Pull the front 3 plug wires & see if there is any oil in the wells,if so you need valve cover gaskets so you might as well do the upper 60K=plugs,wires,gaskets & valve lash. I would not do the front 60K unless your waterpump is leaking or growling or the CPS has a code or its stalling out. I have Valve adjustment tools for sale & a shim kit you can borrow,see my ad in the classifieds & call me, I'll walk you through the process.
--Matt, good to meet ya at convention! Call me about the cam position tools if interested. Thanx
Corby
Porsche Eater
Thanks for the help! Im not sure how to check for the codes though but i know someone who can help me with the 60k, how do you know if you need a valve adjustment, some people say some cars need it and some dont, i was just wondering if theres any way to tell.
SHObill
'The Collector'
After you get the valve covers off use a feeler gauge. Like I said-call me I'll walk you through it. Some auto part stores will run the codes for you- or just do a search here.
LOUDSHO92
Sponsoring Vendor
Thanks Bill. I would be interested.
SHOtimes has a how-to on getting the codes with a paper clip.
If theres a tapping sound you might need a valve adjustment, otherwise it is good maintaince. I would do it.
Corby
Porsche Eater
Yea i would probably have to go to my dads house and do it, unfortunately i have absolutely no tools:(.....but thanks for all of the help!
Black '93
Guest
Lakemoor, IL.
I would say you should put a new CPS in there while it's apart because you don't want to pay a shop to do it if it goes bad and your far from home, and it's a crappy job to do on the side of the road - take it from me. I'd order ALL of your 60k parts from rockauto.com. They have excellent prices and wide variety of brands. Please don't go to Ford because the timing belt alone is like $190 or something rediculous.
LOUDSHO92
Sponsoring Vendor
It can get to be quit costly. It can run around $500-$1k. Unless a place has worked on the SHO they will find it indimitating. You need to find a place who knows SHOs or a locoal SHO person. It is quite easy and you can do it yourself. SHOBros will be renting out the parts soon.
inverse1216
daytona beach, fl
hey corby i know your new in the sho scene but your in the shocago's neck of the woods. you should come to our next meet august 12 (saturday) there is more info in the shocago section of the forum. its pretty close to your town. i can tell you if you have any questions bout 60k ask the guys at the meet theyll be able to point you in the right direction if anything one of them may be able to the job for you if your not capable. see you there!?
andyhttp://www.shoforum.com/showthread.php?t=63784
thatSHOguy101
