DIS Testing
Ruckusnuts
iowa
I was wondering if anyone who has time and a known working DIS could test theirs for me. My module grounds form pin 7 to both of the bottom mounting bolt holes. This tests when OUT of the car through continuity. Ive heard numerous people say it on here it only grounds to one bolt. If so I likely have a short in mine. It took a little bit of scratching to get a good connection but mine definitely grounds through both bottom bolts.
Thanks you all are awesome!
projectSHO89
SHOless In St L
Both lower DIS screws should be connected to pin 7 (ground) internally. See the PCED for more information.
