walser
i got the tranny apart and came to see the roll pin holding the main pin had busted off allowing the main pin to float around the diff and eat a little bit of the case up. but i have a few questions for you MTX gurus. What size steel rod should i use to wrap around the collar and weld to the pin? is the roll pin even needed if im welding the diff pin? what should i do to keep the roll pin from coming out again?
thanks guys
thanks guys
