You have a moonroof, nothing is going to take that away. But some are better than others. Mine is Ventashade universal, part # 779901???, 52 inches long??? Mines great thumbs_u
I assume you have a noise when the roof is open.?
If you still have noise when the roof is closed then it's the gasket around the edge of the glass that needs to be replaced.
I'm unsure, I have to do mine myself.
I think I remember reading here or on SHOtimes.com that you can go via Ford for good chunk of money (~$85??)or you could go to a place that does aftermarket sunroofs for a lot less.
I remember one guy said he couln't afford either so he cut a small piece out of his (to remove the extra from stretching) & then resiliconed(?) it back on & it worked fine.
Check your gasket (small fuzz on it) & see if it's loose especially in the corners (like mine).
Try a new thread on the subject & see if you get some people who've done it. I'll keep an eye out.
