Define rust free?
red89mtx
Guest
kenosha area wi
Yeah Like 6 In Spot And Its Temparary, Aneway I Did It With What Tools I Have Thank You Better Than A Big Hole For Sho
Project Prophet
SHO OFFS
Wisconsin
i hate bondo welding it works way better! bondo will hold moisture and it cracks really easy! not to mention if you dont prep it right pait wont stick!
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
Mike.. I do this kind of work all day. Maybe not on cars but on parts that are way more "high class?" The key to doing bondo work... or anykind of body work is.. you dont want to make more work for yourself. You tend to make things worse and also make it harder to fix the damage... or.. mistake.
Cheers.
HotRodKid
mmmmm ... turbo
Western NY
rust free to me means that theres no rust forming at the seams - as thats the hardest to fix
but slight surface rust can be construed as rust free, as long as "rust free" is said in a casual way, if that makes any sense
if you cant get primer / paint to stick to bondo, there seriosly something wrong, you should never do bodywork again ... ever
or you should stop finishing your filler work to a high gloss ... buffers are for paint, not bondo
StockersAuto
Rocket Powered
Duluth, Minnesota
Rust free means no rust on the body, and nothing more than surface rust on the frame and suspension.
Now, "minor rust" is a tough one. I see ads proclaiming "minor" or "little" rust to be anything that you can't fit more than three fingers through.
red89mtx
Guest
kenosha area wi
id say this is as close to rust free as im gonna get on my car
good solid rockers car was garage kept since 1992
just gotta get that door changed
Picture001 2
Picture002 2
n8rsk8r
Hey Where's my post?
Olathe, Kansas
ilikepoultry
6th motor SHO
Pewaukee, WI
me too, i think that before they go on with alternative fuels they should make cars out of materials that dont blemish... thats how much i hate rust
:madflame:
:rant:
:mad:
:cuss:
:fight:
:help:
how about the stainless-steel delorian? (or however you spell it)
btw... the underside is stainless too... the things can sit in a field for YEARS and not even have a spot of rust
