dead battery
kendal_jones
tha sho off
manchester ct
ok i put my new amp in and a few hours later my was dead so i get a jump and drive it for a while and a few hours later it was dead again the car would not turn over. so i took the amp out the battery still went dead.
etc1006
Baltimore, Md.
I'm gonna say your battery was already on it's way bye-bye... Putting in the amp just helped along. Extra/more load.
Racefan97
Brandon,FLORIDA
Make sure you check the ground that goes from the battery to the frame(near the power steering pump reservoir.) Mine did not have a good ground there and I kept going through batteries. Wish you luck!!
scubasteve
amherst new york
i had that problem and i replace the battery a few times come to find out the alternator wasnt ca=harging at full capacity
If you battery goes dead you should recharge it with a charger. Jumping it and driving around for a couple of hours not only does not adequately recharge the battery but also put a very heavy strain on the alternator.
This is not what the alternator was designed to do. The alternator is meant to replace the electricity that is used when starting the car or minor loads when the car is off. Not to recharge dead batteries which may take a few hours to do the job correctly.
Wht91+
93 Green MTX
Oconomowoc,WI
exactly what happened to mine. but make sure same gauge wire. or you will burn the new battery up faster than the old one.
shopower90
Fosston
If you get a dead battary, the battary is usaully shot if it wasnt a human mistake, having the battary go dead on you a few times is real ******* a battary and will not be the same, like living a battary on concret for a length of time...
Eliw
Brooklyn NY
I dont mean to change the subject, but...
The whole battery on concrete discharge thing is untrue. If it would be possible to suspend a battery in the air, it would still discharge over a period of time. Actually, putting a battery on a cold concrete floor will probably slow down the chemical reaction that naturally discharges a lead acid battery.
Again, I dont mean to change the topic, but myth busting is something I love to do.:salute:
shopower90
Fosston
really thats a myth about the concrete floor? well thats just from past experiances and well what ppl have told me in the past
Eliw
Brooklyn NY
yeah, its always been said. Truth is though that you can leave a car battery on a wood floor and it will still discharge over time.
