Thanks,
I bought a set of APC mini LED ligts that are suposed to enhance the look of headlights(13.99).
They are availible any were Fart Pipes are sold.
The SHO emblem will pop out when you gently pry the top or bottom.
You will see that is a cavity for the interior thermostat climate controll.
I used a piece of brilliant white paper to back the plastic SHO logo.
Attached the green LED on the back of the cavity using the supplied sticky backing.
The rectangled cavity can be gently pried up to allow the small LED wire to pass through and out the glove box.
This wire can be wired in to any 12v dash light.
I chose the remote stereo controll. It was easy to pull pop the switch out and ID the dash light that lights it up.
I the black dash piece that houses the knobs pulls ouit easy enough to run the wire behind it.
I used the other light above the rear lisence plate.
I think they might look good in the Fish tanks as well.
It was cheap and easy.
(Consdering I can't afford the real mods)
