Hi, I have a 2011 SHO/PP with 118K miles. Recently I have gotten a warning chime and pegged temp gauge after quickly stopping from 90 mph freeway speeds and sitting in traffic ( welcome to Southern California ). Coolant level is fine, no DTC thrown, radiator airflow is not blocked. Electric fans start up as expected when I select "max cooling" and set blower at highest speed ( learned that from the shop manual I just bought ). So I monitored the cylinder head temperature with my scanner. There are two of them, one reads about 25 degrees ( F ) higher than the other, e.g. 188 vs 218. Both go up and down with load, but the offset remains about the same.
Any words of wisdom from you folks? Should I just replace both of them? And most important, is this a warning that my water pump is getting ready to pack it in?
Thanks!
Chris
Thanks!
Chris
